Multi Actions
Midi actions can be placed inside Multi Actions or Multi Action Switches with some restrictions.
When a Multi Action button is pressed, the Multi Action triggers a Key press immediately followed by a Key release for each action defined within the Multi Action. This sequence of events has the following consequences for Midi actions in Multis:
Push buttons work as expected in Multi Actions and Multi Action Switches.
Hold buttons do not work in Multis (or rather - work like Push buttons) since the Midi action experiences only a very short key press and has no knowledge of the state of the physical button.
Toggle buttons work as expected in Multi Actions. They also work in Multi Action Switches, but the result might be somewhat confusing...
A Midi toggle action placed in both Multis of a Multi Action Switch will toggle with each button press but keeps track of its state regardless of the state of the Multi Action Switch.
A Midi toggle action placed in only one of the Multis in a Multi Action Switch will toggle with every other button press and keep track of its state regardless of the state of the Multi Action Switch.
Fader buttons do not work in Multis.
Cycle buttons work as expected in Multis except for "hold to change direction", which does not work since the action experiences only a very short key press.
